Question for the guy's with electric waterpumps?
Discussion in 'Drag Racing' started by greasemonkey, Jun 30, 2010.
  1. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Just curious what you guys do to block the coolant bypass on the thermostat housing? I used a generic rubber plug but it appears like it wont last long.
  2. mavman
    mavman Member
    Arkansas
    I tapped the thermostat housing & installed a 3/8" NPT pipe plug. If you can find an anodized aluminum one they work better...and they're prettier. I used a brand new t-stat housing from the parts store. Aluminum. The old one was getting nasty.
  3. rthomas771
    I filled it with JB Weld 4 years ago.
  4. greasemonkey
    Sedalia,MO
    Thats what i was leaning towards. Thanks!
  5. greasemonkey
    Sedalia,MO
    I did purchase a new one awhile back from the zone, but it was cast iron. So i had considered the tap and plug but the hassel of it all, ugh, and those billet ones do look good but geez at the price. Thanks, if the jb(or epoxy) wont work i probably will tap it.
  6. rthomas771
    I tried to tap my cast iron housing and it cracked down the side of the nipple. I even went and bought the correct size drill bit.
  7. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I cut the nipple off flush and then tap the housing 1/4 pipe and put a plug in it.....
  8. greasemonkey
    Sedalia,MO
    Thats exactly what i was afraid of.
  9. 71gold
    1st. one i did i cut the nipple off and threaded it for a short bolt.
    2nd. one i cut it off and threaded it for a brass plug (mounted from the inside out) making it flush with the outside.
    ...:yup:...
  10. olerodder
    olerodder Member
    NorCal
    And why do you say it won't last long. Have had a rubber cover over the nipple for probably 5+ years and it still looks good.............although I probably will replace it when I get a new radiator.....................it will work fine.................IMHO
  11. greasemonkey
    Sedalia,MO
    I put one just like that on mine a couple montha ago and after the first trip to town and back its cracking badly. Maybe i just got some cheap ones?
  12. olerodder
    olerodder Member
    NorCal
    This is a breather rubber grommet, the kind you cut the hole in to push a valve cover breather into. It is just cut off at the top. Has been working fine for a long time.
    IMHO
  13. mavman
    mavman Member
    Arkansas
    I thought about the JB weld deal. But I've seen it come out of different things that were under pressure and/or heat and I didn't fully trust it. Last thing you need (or I need) is for the plug of JB to come out & puke water at 120+ mph at the strip. Water under the tires is nasty.....and I'm only running 1/8 mile. 1/4 mile its even more important.
    Advance auto parts carries new aluminum thermostat housings for like $8. I got mine there and drilled/tapped the hole for a 1/4 NPT plug (or was it 3/8"...can't remember). Less chance for an NPT plug to come out than a big ol plug of JB weld IMO.
  14. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    I have the pretty billet thermostat housing and it was already threaded. But then I had to buy it since it matched my purple accessory themed motor.
