Question on AOD trans for my 73 Comet
Discussion in 'Technical' started by 73cometter, Nov 27, 2019.
  1. 73cometter
    73cometter Member
    Maryland
    73 Comet GT
    Have a 1973 Comet with 302 and manual 3 speed trans, want to install a AOD trans in car, what all is needed to do this change
  2. 71gold
    my AOD install included...
    stock...164 tooth blockplate
    164 tooth 28 oz. flexplate (Summit)
    stock...converter w/AOD and N/S switch pigtail ('87 F-150)
    stock... length driveshaft
    355 rear gear (Summit)
    stock... Maverick floorshifter
    Lokar...TV cable and corrector (Summit)
    TV/TC bracket - SRK-4000 - Throttle Cable-TC1000U
    TV Cable - KD-2AODHT
    one of my ...AOD crossmembers (from Me)
  3. maverick600
    maverick600 Member
    San Angelo, Texas
    What is the length difference between the driveshaft behind a 200 and c4 and the 302 and c4? I'm wanting to do the aod conversion as well.
  4. Krazy Comet
    Dismal Swamp
    ZERO
    71gold likes this.
  5. maverick600
    maverick600 Member
    San Angelo, Texas
    Nice...tanks for that. One less thing I have to worry about.
  6. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
    Make sure you get a c-4 rear seal. You would want to replace this anyway. Many of the later vehicles had a larger diameter yoke.
  7. maverick600
    maverick600 Member
    San Angelo, Texas
    So...how do I get one of those cross members???
  8. 73cometter
    73cometter Member
    Maryland
    73 Comet GT
    I am getting a Performance Automatic AOD with manual valvebody, so I guess the tv cable wont be needed, do I have to get a different trans crossmember , if so where to buy it
  9. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    See the last line of the second post in this thread, 71gold makes them and sells them.
