Question on Cracked shoes
Discussion in 'Technical' started by Phil, Jan 12, 2016.
  1. Phil
    Phil Member
    Southern NJ
    1975 For Maverick
    I noticed that the brake lining on the shoes on my rear brakes are cracked, just 1 or 2 obvious cracks per shoe. Under hard braking one side (I belIeve it is the right side) will lock up. The linings are clean, no fluid on them, new wheel cylinders, no pulsations.
    My question is, could these cracks cause my lockup?
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Misadjustment is a major cause of lockup. I would replace the shoes, hardware, and have the drums checked for minimum thickness.
  3. 71gold
    Crown Vic. rear disc...:yup:
  4. Powerband
    Powerband Member
    NY's \H/
    The cracked shoes may be related to the lock-up problem. If the brakes ever overheated, it could cause lining cracking and related damage.
    Check the Brake Drum for any signs of Bluing - meaning overheated/burnt steel. I've seen smoking red hot rear brakes ruin the drums with blue-burnt areas that apparently distort or roughen and cause grabbing with normal braking friction heat rise.
    (... Oops, left emergency brake on again ...)
    have fun
  5. rthomas771
    Also could be cheap quality shoes. I like to stick to name brand shoes
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I learned the hard way years ago (non Maverick) that buying cheap brake linings is a bad idea. I now always get the best available.
  7. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    cheap shoes crack and fall apart been there done that
  8. Phil
    Phil Member
    Southern NJ
    1975 For Maverick
    I actually have a vic rear disc brake setup sitting in the garage...
    I recently adjusted the drums (evenly), the drums had no signs of hot spots anywhere on them, not to say that they may not have developed since. (the longest i've accidentally left the parking brake on is 2 blocks, not enough to matter)
    Chances are they are El Cheapo shoes, based on the previous owners choices in parts.
    I'll get new shoes and hardware and check the drums thickness, hopefully that will fix the problem!
    Thank you all
    mojo and Crazy Larry like this.
