Question on hotrod c4 post
Discussion in 'Transmissions' started by wrenchingfords, Dec 31, 2007.
  1. wrenchingfords
    wrenchingfords Member
    Canada, Calgary AB
    1974 Maverick 2 dr, 302 76 F250 supercab 460 2004 F250 6.0 turbo diesel 2005 Mustang GT 4.6 5sp stock
    Been preforming mods to c4 and it is very well written!
    Thankyou PaulS :bowdown:
    and anyone else who contributed
    In the section on drum mods...the bleed hole to be drilled at a slight angle from outside of bottom.... is this done with the #56 drill???
    It is not entirely clear.
    Also the spring to be acquired:
    1.95" free lenght, .650" outside diameter, .053" wire......
    Does anyone know a source on where to find such a spring??
  2. PaulS
    Wrenchingfords,
    The small bleed hole is not required unless you are turning your engine above 6500 rpm. The spring can be purchased with a TransGo shift kit #SK4-71. That is not the big reprogramming kit, it is a small inexpensive kit with a few springs in it. Don't do anything the kit says except use the correct spring (I think it is the green one.) The mods that you need are already taken care of in the valve body mod section. I have mine custom made but the kit contains a spring that is perfect for this use.
  3. wrenchingfords
    Canada, Calgary AB
    Thanks, That will narrow my search a great deal.:thumbs2:
