Question on Manual Center Link and Power Steering Pump
Discussion in 'General Maverick/Comet' started by Noahg, Dec 27, 2015.
  1. Noahg
    Noahg Member
    1973 Ford Maverick 4 door
    I am looking to convert my 73 Ford Maverick to manual steering and am wondering if all years for the maverick have the same size center link? I know the difference between power and manual being the 3 vs 2 holes in the link but just want to make sure if i buy a later model link that it will fit on my 73.
    Also when i convert what do i do with the power steering pump? Do I just cap it off when i take off the lines going in and out and leave it?
  2. Craig Selvey
    The manual steering center links are different. 1970-1974 is different from 1975-1977 set-ups. The parts do not mix with each other as far as center link and pitman arm. Parts are easier to find for the 1975-1977 set-up in my opinion. I have the parts if interested....email me DIRECTLY (see below) if I can help.
  3. Lee Richart
    Lee Richart Member
    Redford, MI
    1973 Maverick LDO 421W
    As for the power steering pump. When I originally converted mine to manual, I made up an idler pulley so that it would still run the water pump. You don't want to run the power steering pump dry. Later on I found a different water pump pulley at NPD that would line up with the alternator and now one belt runs the alternator and water pump. Then I could eliminate the idler pulley. More recently I have installed a Borgeson power steering unit and it runs off the third or rear groove on the crank pulley. Of course all bets are off if you have a different style crank pulley. Good luck.
    Lee "THE MAV" Richart
  4. Krazy Comet
    For temporary you can cut the pressure hose and loop it back to the pump return, not very elegant but will work...
