question
Discussion in 'General Maverick/Comet' started by 289, Oct 14, 2013.
  1. 289
    289 Member
    Prescott Wisconsin
    73 grabber
    im trying to figure out if my maverick has an aftermarket ring and pinion gears.
    speedo says 50mph
    and im cruzing at 2500rpm
    i have 26in tires
    that seems a little high for me to have the stock 3.00 gears. BUT im new to this so i can be wrong. anybody have some info? im guessing the speedo is lying to me a little bit and im probably going a couple miles a hour faster because i have 26inchers.
  2. olerodder
    olerodder Member
    NorCal
    If you have an automatic.....I assume..............and your speedo is correct (which is not likely if the rear end gears have been changed) and you are cruising at 50mph with 26" tall tires and doing 2500rpm you have at least 3.73's or 3;89's........or somewhere in between.
    Jack up the rear of the car, put the trans in neutral.....put a mark on the rear tire and turn the tire one complete turn (360 degrees) and count the number of times the universal goes around, that is the quickest way to make a guess................which may be better than your speedometer.
  3. 289
    289 Member
    Prescott Wisconsin
    73 grabber
    Thanks rodder, ill get a gps and see how much the speedo is off and ill spin the tire too. the guy i bought it from said he used to drag..which makes sense
  4. olerodder
    olerodder Member
    NorCal
    You are welcome.
    How about some pictures of your car?????
  5. 289
    289 Member
    Prescott Wisconsin
    73 grabber
    well this is the most recent photo of it yet, ill take some nice photogenic pictures of it later this week. she is beat up and a little rusty.
    update-
    the speedo is off 8mph at 50 i was actually going 58 @2500rpm
  6. olerodder
    olerodder Member
    NorCal
    Looks good, just a little rust repair................
    If you were actually doing 58 it could be between 3.25's and 3.5's.......but you need to do the U joint count to know.
  7. rthomas771
    Someone might of changed the speedometer gear. Sounds like you're one or two teeth off.
