questions about air & fuel
Discussion in 'Technical' started by dudi, Jun 16, 2007.
  1. dudi
    dudi Member
    hi
    what is the difference between the intake "stage 2" to weiand "Stealth" ?
    i have holley 4150 DP 600 cfm , i know that this carburetor need 7 psi
    but how much gph the fuel pump need to Flow ?
    the engine is 302
    thanks
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
  3. PaulS
    The fuel needed depends on the rpm and the amount of HP your engine develops. If the engine is stock then the stock pump will work fine. If it will turn 7000 rpm the stock pump should be replaced with a higher output
  4. ratio411
    ratio411 Member
    Pensacola
    Paul is right.
    When my engine was quite a bit beyond stock, I used a Carter strip pump with great sucess. It looks relatively stock, is cheaper than the shiny ones, and puts out alot of GPH/pressure for a mechanical pump.
    It certainly wouldn't hurt a mild engine either, but may be overkill.
  5. dudi
    dudi Member
    i have 88 engine so i dont have place to mechanical pump .
    the engine is not ho it's efi from lincoln town car and it stoke .
    i'm searching an electric fuel pump .
    i have bosch fuel pump that flow 245 lbh at 35 psi, so if i will install a regulator to lessen the presser to 7 it work good?
  6. bmcdaniel
    I run the Carter street pump, too. It's basically the same pump that came on the Boss 302s, and you know how they reved. Back in the early 70s before high performance aftermarket pumps were readily available at a deecent price we would go to the Ford dealer and order up a Boss pump for our 289s and 302s. I would recommend you stay away from the Edelbrock and others 6-valve pumps.
    As far as fuel amount required, check here:
    http://www.slowgt.com/Calc1.htm#FPHP
  7. Slantsickness
    Slantsickness Member
    Tucson, Az
    1975 2 Dr.
    If you're switching the engine to a carb, you can switch the timing cover and run a mechanical pump. It would keep things simple for you, unless you really need that electric pump to push your gas, but it dosen't sound like you do, at least not yet.
  8. mcknight77
    mcknight77 Member
    Boise, ID
    74 Mav drag car, 1970 Maverick, 1971 Bronco, 66 Nova, 67 Ranchero
    If you're switching to a carb you don't need that high psi pump. A simple electric fuel pump from any of the parts houses will supply the fuel. Or, as stated above by Slantsickness, just convert to mechanical. The low pressure electric is simplest and cheapest. And, you can always upgrade later.
