Quick intake poll
Discussion in 'Technical' started by justin has a 74, Nov 24, 2009.
which intake
  1. rpm intake
    34 vote(s)
    89.5%
  2. victor jr intake
    4 vote(s)
    10.5%
  1. justin has a 74
    kentucky
    Although most of the engine builders told me no, i have to include that the VICTOR JR intake is only 1 inch higher than the RPM INTAKE
    Another choice is to go back to the 2 barrel:naughty:
    So here we go real quick, please select one ONLY if you have knowlege of these please.
    all specs are in my sig. thanks
  2. rthomas771
    What rpm do you expect to be cruising? If less than 3000-3500 then use a dual plane. The single plan is for high rpm or all out racing and are a slug at lower rpm
  3. safado
    safado Member
    West Phoenix, AZ
    what heads do you have? thats a small cam.. i vote rpm
  4. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    For the combo in your sig ,you`d need the RPM
  5. mean_maverick
    like ive mentioned before..... rpm
  6. Dave B
    Wow, we vote on all your stuff.
  7. Joe Dirt
    RPM only.. ....
  8. Dave B
    I like Weiand intakes, the best.
  9. bradleygt
    bradleygt Member
    grand rapids michigan
    1970 maverick
    for that small of a cam id go with the plane old performer non rpm but thats just me
    save the victor for when you build a engine with more beans:D
    brad:)
  10. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    Weiand dual plane.
    I like them best because I like to say "weiand".
    WEIAND.
  11. Moneymaker 1
    Panama City Florida
    Weiand who else?:tiphat:
  12. baddad457
    None of the above. My money's on the tried and true Ford A321 and all it's predecessors (F4B, Cobra highrise, Ford C9OX) But the RPM will work just as well, as will a Weiand Stealth on your motor. The std Performer is nothing more than an aluminum version of the old stock iron 4 bbl small block intake.
  13. sierra grabber
    sierra grabber Certifiable
    northern nevada
    i voted RPM cause dats wat i gotz.... seriously though you will need a 1" tall k&n with a drop filter base to clear a grabber hood, and 2" should work with std hood with the RPM.... has been good to me so far.
  14. lbr
    lbr Member
    Fresno, CA
    11 second '72 Comet, 302, 4 spd
    I run a RPM on my 302 and it works well enough to run 11.40's.
  15. lbr
    lbr Member
    Fresno, CA
    PS without any spacer.
