Quick question...Rearend width?
Discussion in 'General Maverick/Comet' started by ScottsGT, May 15, 2009.
  1. ScottsGT
    ScottsGT Member
    Columbia, SC
    No Maverick, yet. DD is a '95 Mustang GT convertible
    Did a search and came up with 56.5" from outside of drum to outside of drum. Correct? Got a line on a Maverick 5 lug 8" rear cheap, so I want to verify.
    It's pretty bad when I'm buying V-8 parts even before I get a Maverick! I guess I can always sell it if I don't find a Maverick.
  2. mean_maverick
    yup, that's the right width
  3. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    Confirmed this for myself just last week.
  4. CaptainComet
    Yeah, but if you get a Granada/Monarch rear, you can fit more tire under there if you are using old-school wheels. Those are 58" and the spring perches are in the right place. The stock axle is a bit snug to the frame rail.
    Why are you buying an axle before you get a car? ... screamin' cheap deal?... if so, go for it ... street rod guys love Mav axles ... old cars are really narrow.
  5. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    Rear End Specs
    Here are all the Rear End specs for a factory Maverick Rear End. This is the build sheet for the rear end I just got from Currie. It is a 9" housing built to exact specs for a Maverick. Hope this helps more than just one person.
    BenRM likes this.
  6. ScottsGT
    ScottsGT Member
    Columbia, SC
    I see what you are saying, use a wider axle, more BS on the wheel? I'm kind of leaning towards the Magnum 500 look or a set of old school torque thrust D's if I get one. If I really get bored, I'll pro street it with a real set of meats under it!
    I think it is coming out of a streetrod. Guy is also trying to sell a TH400, GM tranny.
    $50 screamin' enough for ya! :thumbs2: Picking it up Sat. morning.
  7. DaMadman
    Southern MD
    Maverick 1972,1970,1973
    It's a good thing (for you)we don't have many females on this forum :rofl2:
  8. Duck Tape Mav.
    Vilonia, Arkansas
    that would be an interesting discussion topic to say the least. something tells me this thread would have a lot more replies, though.
  9. AllRoundCarGuy
    AllRoundCarGuy Member
    ND
    1970 Maverick Restoration
    What cars rear end with a ford 9" would be a direct bolt on without moving any mounts for the springs or anything else looking for a rear end but cant seem to find one out of a maverick.
  10. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    65-66 Mustang
    57-59 Full size Ford
    Granada/Monarch
    Those rears are all the same width, which is WIDER than a Maverick.
    However, they bolt right in...
    There are several others that bolt right in also, but they are significantly wider than stock.
    *The Maverick never came with a 9" rear.
  11. sierra grabber
    sierra grabber Certifiable
    northern nevada
    with the fact you pretty much have to cut it anyway, what would you have to cut on a truck rear end as opposed to the mustang one? rear ends are one of the less experience pieces i have but there are so many truck nines and so few of the needed car ones?
  12. Duck Tape Mav.
    Vilonia, Arkansas
    i just missed out on a truck 9inch rear for $50 with the wrecked truck body. told the guy i'd be interested, and someone beat me to it. *banging my head against nearest wall for not looking at craigslist a day sooner.*
  13. CaptainComet
    The axles that Ratio lists are an OK fit in a Mav ... about two inches wider overall, which places the rear tire more in the center of the wheelhouse. From the factory, ours are a bit too snug inboard. With these axles, you could get more rear tire in there while still using old-school wheels. These axles also already have the spring perches in the right places.
    Truck axles would get pretty involved ... the bolt pattern is bigger or even six bolts (different axles) ... need to narrow ... weld spring perches on it. I believe all truck axles are 31 spline, too.
  14. sierra grabber
    northern nevada
    yeah i know they would have to be narrowed but so would any car one that isnt listed by ratio, and possilby some of the ones he did list as well? same for perches? the bolt pattern could be the main problem with them, dont know why i didnt think of that, since i tried putting the spare exploder rims i have on a bronco and they didnt fit :slap: :rolleyes:
  15. ScottsGT
    ScottsGT Member
    Columbia, SC
    65-66 Mustangs had an 8" Only the Shelby (and maybe the K code cars?) came with a 9" Good luck finding that in a bone yard :D
    VERY few Granada/Monarch's came with 9" rears. The 9" was for the Lincoln Versailles, and a few got pulled from the assembly line when 8" ran short on inventory. I've got a Versailles 9" in my '66 GT Fastback. The money I spent on it is not worth it these days. That is old school technology since there are so many rear disc options for 8" and 9" rears these days for a lot less. Check out Mustang Steve (Google him) and you can find adaptor kits for '94 to '04 Cobra brakes to Mustang and Maverick rears and spindles. Only drawback is that you will have to run 17" wheels.
    EDIT: Don't forget having to have that Cobra Spare tire too! That's another $200 off of E-bay!
