Race weight..
Discussion in 'Drag Racing' started by 1badmav, Oct 11, 2006.
  1. 1badmav
    1badmav Member
    trying to make an engine combo decision..I need to know what the weight of you maverick/comet is without driver ready to race..Im going to have a stock suspension fullinterior car with only a fiberglass hood and two kirkey aluminum seats,can anyone give me a round about weight...Thanks Roger
  2. scooper77515
    I estimate mine at 2700 lbs, minus driver. Mine is stock minus the big bumpers, replaced with small ones, and as much stuff taken out as I can. Bucket seats replacing the bench, and a plywood "dog perch" instead of back seat. All "crap" taken off the engine (not worth more than maybe 20 lbs total).
  3. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    i hoping mine weighs in at about 2500-2600 , i have small bumpers,all steel, guted interior(for now) fuel cell (no tank) no ps no ac, i hope to be in that range maybe i should loose couple pounds:D
  4. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    mine is around 2600 without me in it. fiberglass hood most interior and a fuel cell.
  5. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Have to know what year Mav. My 77 is not lightened except for aluminum heads and intake, and headers, with 1/4 tank of fuel weighs about 2950
  6. stmanser
    Davenport, Iowa
    mine is 71.. small bumpers... no interior... with driver 2850 and i weigh 220 pounds..
  7. igo1090
    igo1090 Member
    catonsville, md
    74 4 door. 3250 with full tank, alum intake, no ac, no ps, alum wheels.
  8. scooper77515
    It is nice to see that I probably wasn't too far off on my original estimate :D
    Not bad for just "guestimating"...
  9. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    69 1/2 everything I have done to car has added weight, and its still only 2620.
  10. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    I bet your wieghs more like 2900-3100lbs. Mine weighs 2750 without me and the early 69.5s and 70's were the lightest of all mavericks
  11. scooper77515
    STill, not too far for a quick estimate...I took the 72 model (last year with small bumpers) then added weight due to the door reinforcement bar, then removed weight from items I took out, and got this ballpark figure.
  12. mavman
    mavman Member
    Arkansas
    Before I backhalfed and did the Mustang 2....stock chassis Maverick 31 spline Mosers (heavier) in a 9" (heavier than the 8") full spool, big drums on the back, stock drums up front...basically a stripped '75 Maverick 2 door with one fiberglass seat and no back seat. Door beams were removed. Plastic windows, aluminum heads, 351w/powerglide. Light aluminum dash. Weighed 2580 without me in it. I'm around 160 lbs.
    After I backhalfed it and put in the Mustang front suspension, I figure it lost ~300-400 lbs, maybe more. But, I put the 14 pt. rollcage in so that added a little bit back. Engine & trans didn't change, but the car picked up .3 in the 1000' ET just by doing the backhalf and mustang 2 IFS. Went from 8.65 best to 8.34 best. MPH didn't increase a whole lot (maybe 2 mph, IIRC) which is an indication that the HP didn't change any. I think it went from 114 best to 116, IIRC.
  13. eddie1975
    Martinsburg, WV
    sold
    awesome thats just right around the weight i was looking for, so i should be close to my guessmitent:D i still have 8 inch , c4 is that heavier than a PG and my car is a 75 small bumper, execpt im about 235 lbs :D maybe if i loose couple pounds ill be closer to my weight i want....:D
  14. bossmav
    bossmav Drag racing nut
    Harrisonburg, Va
    74 Grabber now Pearl white
    eddie1975 you are not FAT!! Coming to MIR next weekend?
    My car has the small bumpers, no passenger seat with me in it 2980
    351W stroked to 408, Vic JR heads, one SWEET C4, ford 9 inch,
    and a 165lbs driver.
    So 1badmav tell me what motor have you chosen?
    If I had to do it all again, there is a motor SITTING on the floor at a local speed shop where I live.
    Dyno power 510 ponys, now I know that doesn't sound like much but for a STREETABLE 347 it kicks A$$.
    Years agos I posted all the info and the dyno sheet on the motor so if you look at my posts from 2 or 3 years back you might find it.
    ALL FORD POWER AT MIR on the 21 and 22 OCT one hooken track.
    AS seen on PINKS http://www.mirdrag.com/
    Hope to see as many of you there as I can.(y)
  15. bossmav
    Harrisonburg, Va
