radiator cap
Discussion in 'Technical' started by 351wmav2, Aug 2, 2006.
  1. 351wmav2
    351wmav2 Member
    Hermiston, oregon
    71 maverick
    i was going to replace my crappy old radiator cap with all the other stuf i gotta get done on my car, i went to buy a new one today and seen that there are 13psi and 16psi caps.....what one do i need? why are there different ones?
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    13 is factory ...
  3. Texas 71
    Texas 71 Member
    Orange,Tx.
    To answer your question about why there are different ones: Water boils at 212 degrees F. and for every one pound of pressure you put it under it raises the boiling point about 7 degrees. So a 13 pound cap will raise the boiling point of the water to around 300 degrees.
  4. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    I dont think it is that high. I think its about 3 degrees per pound but I need to check on that.
    With all the mods you have done to your engine go with the 16, it will give you the best performance.
  5. igo1090
    igo1090 Member
    catonsville, md
    keep in mind that the higher pressure cap will stress your cooling system more and may acquire a leak sooner.
  6. dmhines
    Cumming, GA
    Whenver going to higher rated caps ... make sure your heater core hoses and heater core itself is in decent enough shape to support the extra pressure. Wouldn't want a burst heater core ruining your carpet and your day ...
  7. maverick1970
    maverick1970 MCG State Rep
    Missouri
    3 Degrees per lb is correct
