Radiator Repair
Discussion in 'Technical' started by Bioinfomatic, Dec 10, 2007.
  1. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    My OEM radiator has split 1/4 inch apart at the top seem, and when I drive the car it blows a lot of steam out of that hole, Is there anyway I can repair the radiator? :huh:
  2. don graham
    you can take it to a radiator repair shop. but i would bet that it would cost almost as much as a new one. and you'd still have a 30+ year old radiator. i'd opt for the new one if you can.:)
  3. 71gold
    ..best to park the car untill fixed...:yup:
    ...Frank
  4. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    Thats a good point, but a lot of guys around here at the other local shops suggest I have it repaired, because its really not that bad. Other than the cho-cho train effect it has once it gets warmed up.
  5. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    I guess because there is a good chance I could blow the head gasket?
  6. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    If you have a rad shop thats good, take it to him an let him decide. One in Blairsville Pa Looked mine over an said to replace with new. Thinking it was near $180 and a quailty one! I thought he treated me fair. He does get all my business, before an after.
  7. 71gold
    ...:yup:...
    if it's the org. radiator it will just spring a leak somewhere else...
    ...:bouncy:...
  8. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    What good would that do if the radiator still has the hole in it? :hmmm:
  9. 71gold
    "Thats a good point, but a lot of guys around here at the other local shops suggest I have it repaired."
    "if it's the org. radiator it will just spring a leak somewhere else."
  10. Jamie Miles
    My grandpa's '78 Bronco sprang a leak back in '04. I took the radiator to a shop and had them solder it up. Cost 10 bucks... has been fine since then. But that truck is rarely driven more then 4 or 5 miles down the road, it's mostly used to just run around the fields, mountain and other property my grandpa owns in NC. On a vehicle that is depended upon to drive further then a few miles on a regular basis, I would just replace the radiator with a new one... Would suck to find out when you are 70+ miles from home that you have another thin spot...
  11. 72MAVGRABHER
    Roanoke, Va.
    1/4" is pretty bad...
    soon as you fix it, your system will find the next weakest link and blow that out. Overheating kills engines, so if you're having to drive it, check the antifreeze everywhere you go, you can't be too careful. Yeah a new radiator would be around 200 bucks for most, but it will last you through the years instead of rigging it now. But, again, money is an object....
  12. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    After I had the radiator repaired, it found a new hole to leak from. (You guys were right.) So I purchased a new radiator from Advance Auto Parts for $100 yesterday. After the install and a few test runs, My gauge is telling me that the temperature is 210 degrees, goes back down to 160 degrees. This process repeats itself while I'm driving. Also a few times i will stick at a 151degrees what could the problem be? A sign for a new thermostat? :huh:
  13. Bluegrass
    Bluegrass Jr. mbr. not really,
    Easton, Pa
    73 Comet GT, EFI, C4, Posi
    I can't believe this conversation is going on over a radator.
    You first didn't want to replace an old one and now you don't replace the thremostsat for the small cost and keep having ongoing issues.
    What about the hoses? Are they old and hard?
    What about the pressure cap?
    The system operates at about 16 psi and will blow old hard hoses at some point.
    Point is to service the WHOLE system and give yourself a break from going back and fixing it more times than you need to..
    Cost the same in the end but more work.
  14. gdemopesq
    gdemopesq MOTOR CITY MAV
    Michigan
    72 Maverick 302
    new one
    I picked up weel built aluminum one on ebay for $200. Looks good well made. Wont need another after that
  15. 72MAVGRABHER
    Roanoke, Va.
    sorry....
    but i told ya so.
