radiator support
Discussion in 'Technical' started by ronr11, Jan 16, 2005.
  1. ronr11
    ronr11 Member
    hartsville sc
    71 maverick
    the 70 grabber is welded but my support on my 71 is bolted on as are the ft inner side panels where the battery backet and washer tank are bolted , question is are the parts out there anywhere thanks ron:tsk:
  2. Mavaholic
    I've never seen bolted on panels. They are all welded from the factory.
  3. Mavaholic
    Oh, and there are no reproduction core supports or fender aprons.
  4. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Wow ... never ever seen a bolted in radiator support on a Maverick ... they were defintely spot welded at the factory ... I know because I've air chiseled one off.
    There are bolts on the fender aprons but they are used to bolt on the coil spring outer cover inside your fender. The fender aprons are welded in as well ...
