Ram Air on a Mav
Discussion in 'Technical' started by 70ProStreet, Dec 2, 2008.
  1. 70ProStreet
    70ProStreet Member
    Taylor, Michigan
    Has this been done before?
    I was think it would be cool. Maybe not on my car, but whe I get another Mav (I'm sure I will) this would be a cool idea.
    Air could be drawn in through a grabber hood with the scoops cut out, or cut out the grille turn indicators and draw air in through there.
    What do you think?
  2. newtoford
    newtoford Member
    New Castle Delaware
    ive got a comet GT hood scoop on 2 of mine and an open filter underneath and i can feel a slight boost of power
  3. 70ProStreet
    70ProStreet Member
    Taylor, Michigan
    Well, with the tunnel ram I just got, a mocked up carb can be seen through the scoop.
    Not sure if I will use this with the 347, but I can always swap manifolds/carbs.
  4. don graham
    jmgford has a nice set up on his Maverick. You can go to the gallery and see it.
  5. 71gold
    something like this..
    ...:yup:...
  6. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    yes its been done before.
    I am working on "something" around that general idea on my car :thumbs2:
    *But, always try to remember; what good is tons of air in if you can't get it out.
  7. 70ProStreet
    70ProStreet Member
    Taylor, Michigan
    I was think something like this would just look fierce.
  8. rthomas771
    Here's one on a Mustang 6 cyl. I guess cold air is cold air
  9. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    These are my favorite cold air setups... Torino flavor is my personal preference, but the Stang version looks good too.
    This is what I had on my 75...
    When it had a 302, you can see the hole in the hood exactly matched to accept the air cleaner. Only the top half of the air cleaner would protrude through, so the top of the element would always get dirty very quickly like in the Cleveland pic. The scoop is still on the car, but in a sad way...
  10. ratio411
    ratio411 Member
    Pensacola
    Nice!(y)
    What scoop does it use?
  11. Zac
    Zac Member
    Woodstock, Ont Canada
    I use a velocity stack thru the hood and it sit's right in the middle of the scoop, thru the hole. It has always worked great, even in the wet. On the rare occasion I get caught in it. Look in my pics.
