ram air
Discussion in 'Technical' started by texas_maverick, Sep 4, 2005.
  1. texas_maverick
    texas_maverick Member
    Telephone, TX 75488
    71 ford maverick
    i was wondering if it was possable to use the grabber hood cowls for ram air and still maintain the screen look to it.
  2. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Yes, either drill out the holes in the original piece or get a piece of expanded metal screen to fill them. Don't really think it would make a lot of differnce unless you make an air box under the hood to feed the intake though.
  3. Jamie Miles
    The only good I can think of it doing is getting cool air in. The scoops don't catch enough air to have any noticeable performance increase.
  4. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Like Jamie said ... in a Wind Tunnel the airflow probably hits front and goes right over the car so those scoops are probably in a vacuum and it would probably pull air out of them instead of force air in ...
  5. RabidCustoms
    I have the ones in the 77 opened up, drilled them out then took a small file to make the honeycomb mesh as open as possible. the only thing I have noticed is that you get a few more bugs in under the hood,and a very slight amount of water if you get caught in the rain. I do think it helps a just a shade ,as far as extracting the hot air after the car has been running.I did it mostly for cosmetics.
  6. texas_maverick
    Telephone, TX 75488
    71 ford maverick
    thanks for the info, i was going for looks rather than performance. for some reason the moter gets hot. i thought i could cool it down some with freash air.
  7. fordman
    fordman Member
    lufkin texas
    1972 maverick
    here is a set up i use and it works 3 tenths at the track i got it for 100.00 but i think it has gone up but 3 tenths for 100 is cheep its called the ram air box
