Rattling belt gear
Discussion in 'Technical' started by skaz, Sep 8, 2006.
  1. skaz
    skaz a.k.a. Steeb
    Phoenix, AZ
    74 Maverick, 73 El Camino
    All righty guys, I've got a big question.
    The Maverick had a rattle coming from under the hood. So I start her up and look for the source of the noise, and the gear below the fan (that turns the power steering pump) is jiggling. I turned off the car and saw that the power steering belt is twisted.
    So I pull off the belt.
    And well, now it's just hard to turn the steering wheel, but I still get that rattling noise. Don't know if it means anything, but it's two smaller belts that run around that gear, the fan gear, and the alternator.
    Help me. :16suspect
  2. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    are you talking about the crank pulley? i think thats what your talking about, anyways try tighting up the crank pulley should be 4 bolts in the center , i think thats what your talking about that may be the source of your rattle
    eddie
  3. skaz
    skaz a.k.a. Steeb
    Phoenix, AZ
    ...yes. Pulley, not gear. 'Scuse me.
    It's way down there at the bottom and I'm pretty sure there's just one central bolt. I couldn't get at it with a wrench, I'll go at it with a rachet tomorrow.
    Any more ideas, in case?
  4. blugene
    Better check them bolts for damage...
  5. skaz
    skaz a.k.a. Steeb
    Phoenix, AZ
    Another thing. It's like there's two pulleys there.
    One that turned the power steering pump, one belt. Then another than went to the alternator and the radiator fan, two belts, behind the power steering pulley. The rearward one is the one that's jiggling.
  6. eddie1975
    Martinsburg, WV
    sold
    yeah if that loose that will rattle like hell, dont take the center bolt out that bolts to the crank and holds on harmonic balencer , there are 4 bolts around the outside of that bolt, might be 9/16 or 5/8 bolts , keep us posted and good luck
    eddie:drink:
  7. eddie1975
    Martinsburg, WV
    sold
    yeah they may have broken off , i dont know i cant remember of ever hearing abything like that but i think it could happen
  8. blugene
    The pulleys are all one piece, attatched to the ballancer, which I believe is actually a dampener, I think.
  9. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Yeah, that would make a hell of a racket. And dual pulleys would sure be the trend of the era.
    Dan
  10. skaz
    skaz a.k.a. Steeb
    Phoenix, AZ
    Girlfriend just remembered seeing a few empty holes around the main bolt. Oy.
    Anyone know the width and length of those there bolts? Looks like a trip to Home Depot.
  11. eddie1975
    Martinsburg, WV
    sold
    well if they are broken off you might want to invest in an easy out, if they just fell out , you might be ok, its prolly 1/2 inch bolt act size of bolt where threads are, and 1 1/2 long not sure on that one though
  12. skaz
    skaz a.k.a. Steeb
    Phoenix, AZ
    Crap.
    Easy out? What is this .. "e-z oot?"
  13. eddie1975
    Martinsburg, WV
    sold
    an e-z out , pulls broken off bolts out by drilling a hole in the bolt an then a piece looks like a corkscrew, thread it in, to the left of course it should start turning the bolt out , pretty straight forward, you can get it at tractor supply , home depot , lowes ,etc directions are on the back of them , and 15 bucks should cover that, but if they feel out you wont need it
    eddie
  14. don graham
    tighten the bolts on the pulley and start it again. if it still rattles then you may have a crankshaft problem. :mad:
  15. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    If you do have to use a e-z-out....try drilling the hole with a left hand drill bit. You may get lucky and it'll back out while drilling. Good Luck(y)
