re-locate battery
Discussion in 'Technical' started by alex70mav, Mar 4, 2012.
  1. alex70mav
    alex70mav Member
    huntington beach
    1970 ford maverick 302
    how hard is it to re locate your battery to the trunk? what is all you have to do?
  2. Bizzness
    Bizzness Member
    71 grabber 351w, c6 ,9" 4.56 locker, subframe, roll cage
    It's some work u gotta make something to hold it and run new cables. It's not to crazy. Check out my pics
  3. Resto
    Resto Benders Evil Twin
    Yuma AZ
    No Big. Long red cable, batt box mounted to trunk floor, black cabble to frame rail. Id use 2 Batts in paralell, with a cut off switch, dont forget a long charging wire from the Alt, Personally.. I would also connect an outside plug to the Batts for Jumps. Its an aftermarket conector made for chargers on things like floor scrubbers, you can cut one of the sets of clamps off of some good jumper cables and put the female connector on them. They sell aftermarket kits for that. I did it long ago for fleet vehicles during Govt Service. IMHO.:)
    Tech Article...Anyone?
  4. alex70mav
    alex70mav Member
    huntington beach
    tech article with lots of pics!
  5. alex70mav
    alex70mav Member
    huntington beach
    what kind of cables do you use to re-route? link?
  6. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    When I did mine I used 1ga to go from the solenoid to the trunk and 4ga to ground to the frame rail at the bumper bolt.
  7. Streamliner
    Streamliner Member
  8. 71gold
    when you measure for the long cable , add 2 feet. my measurement was dead on and that made it a little tight to hook up...:yup:
    don't cheap out on the...disconnect switch...get a good one...the first time...
    ...JMO...:bouncy:
  9. don graham
    My long cable was a welding cable.:)
  10. 71gold
    that's what I used...:thumbs2:
    we have a battery company in town that i took the cables to and had them crimp the correct ends on them...:yup:
  11. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    And spell check.
  12. alex70mav
    alex70mav Member
    huntington beach
    did i spell something wrong?
  13. Bizzness
    Bizzness Member
    Maybe the speak a different language in the " shadowlands "
  14. ShadowMaster
    The ShadowLands
    1969 1/2 Maverick
    No.....but Resto ran the gauntlet.
  15. alex70mav
    alex70mav Member
    huntington beach
    so i tried to feel my way up to cable and the hose for ac/heat is in he way -____- too many obstacles
