reading vins and such
Discussion in 'General Maverick/Comet' started by mavsown, Sep 7, 2003.
  1. mavsown
    mavsown Member
    73' Mav 302 3spd k&m floorshifter
    i have a '73 302 mav. I would like to know how to read the codes expressed on the door jam. they read: body 62a, color 3D, Trim HB, Trans 1, ax 6, DSO 57. The engine code in the vin is F. I dont believe it has the original engine. id also like a brief explanation on how to read vins.( i have a partial knowledge of them) id be forever thankful to anyone who could decifer these for me. :bananaman
  2. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    62A = 2dr sedan
    3D = if you wear 3d glasses while driving you could be in trouble. hehe really it means med. blue metallic.
    HB = med blue, vinyl interior
    1= 3spd manual
    6= 3.00:1 gear ratio
    DSO57 = Houston
  3. Dan Starnes
    West Central IL
    oh yeah forgot VIN tutorial
    F 3S56H123456 F
    start with the first number 3 = year
    second digit S = Allen Park,,, which is assembly plant
    next two digits 56 = 4dr HT Galaxie 500...type of car
    next digit H = engine which is V-8 351 2V
    last 6 numbers are the production sequence
    Dan
  4. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    and if you REALLY want some cool stuff, look under the drivers seat between the seat springs and the foam padding. if you are lucky you should find the "build sheet" it was masking taped to the car as it went down the linee... if you find it, it is very brittle. remove it gently! i had mine laminated. a conversation piece at shows!
  5. mavsown
    mavsown Member
    thank you sooo much. im a new mav owner and new to this forum. im convinced that you guys here are great. thanx again!!!
