Ready To Run Distributor
Discussion in 'Technical' started by Bioinfomatic, Jul 14, 2008.
  1. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    For a 351w my dad is suggesting a ready to run distributor, but they are very expensive...can't I just buy the Mallory 8555401c distributor and convert it to a ready to run distributor?
  2. bmcdaniel
    Why wouldn't any distributor be ready to run?
  3. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    What exactly are you meaning "ready to run" ?
  4. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Ready to run meaningit has a built ignition module etc.....
    personally I like MSD mechanical advance only dizzy....
    Easier to tune....
  5. Andysutt
    Conway Arkansas
    1972 Comet GT
    What's so wrong w/ a duraspark box and dizzy?
    What kind of motor is this going in? If its just a stocker, I don't see spending the cash on that type of dizzy
  6. baddad457
    Ready to run? Buy a reman points distributor, replace the points with any of the electronic modules and "wa-la" you have a ready to run electronic distributor. Reman with core: $55. Pertronix I unit: $60-70. Total cost: around $120.
  7. Andysutt
    Conway Arkansas
    1972 Comet GT
    Or buy a duraspark dizzy from your local parts store... $50
    and the duraspark box for $30 tops (i get them for 18 but partsamerica.com shows em for 28)
    $80 and you have a great ignition setup...
  8. baddad457
    :thumbs2:+ two , especially if the car's already wired for it, it's what I did with the unit in the Comet......85 reman GT Stang distributor from Advance Auto: $55 with a core (any core willl do)
  9. Andysutt
    Conway Arkansas
    1972 Comet GT
    Wiring in a box and dizzy isn't all that hard even if you don't have the wiring.
    Either 1) rob the wiring from a donor car or 2) use butt connectors to fit the plugs or 3) cut the plug on the dizzy and box off, and get a 4 wire flat trailer plug. lol Ive done this several times and it works pretty well also.
  10. Dave B
    Man, Duraspark is so antiquated, save the money and buy something more modern.
  11. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Could go with something like this. I've been running it for about 8 months now with no trouble. Later added an MSD box to it. Purists will hate you for putting "Chevy junk" in your car, or maybe tell you all about how flawed the HEI design is, but it's a good part. It's proven very reliable for me and it was extremely easy to set up. Most importanly, it was ridiculously cheap. :thumbs2:
  12. Andysutt
    Conway Arkansas
    1972 Comet GT
    LMAO, I find that hilarious.
    Duraspark was the base for a lot of aftermarket ignitions.
    There is absolutely nothing wrong with a duraspark ignition, especially on a daily driver. There's no reason to put a $400+ ignition on a other wise stock motor, especially since some people may have gotten their cars for just a tad bit more than the price of that dizzy
  13. baddad457
    The HEI is a good unit BUT IT'S BIG AS A HOUSE!!!!!!!!!!! Like having a big red head hogging the view, you can't see the motor for the distributor!!!!!!!!:biglaugh::rofl2::yahoo::biglaugh::rofl2:
  14. baddad457
    :deadhorse For some reason, this sounds like so many cam comments. What's antiquated about it ? Ford used it until they went to the DIS in the Mod motors. And I think they only did that to keep us hot rodders from carbing them easily.
  15. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    My car isnt ecu controlled and I'm running a carb 351w...I can use any 3 wire distributor and connect it to my external coil and start the engine? "the term ready to run distributor"
