Question?, and advice. Can someone please tell me how to connect the switch from the column to floor shifters. Thanks
'Sounds like you're talking about Reverse lights and not "brake lights". The floor-shifter uses a completely different switch which it mounted on the shifter itself.
Thank you, but no. I switched the gear shifter from the column to the floor. And I need a picture of the reverse light switch.
what floor shifter do you have? this is for a stock Maverick floor shifter... http://www.mustangsunlimited.com/itemdy00.asp?T1=SW1615+01
Frank, I don't remember where I got them from. I got 2 when I need it them. They where 12 inch and I cut them to 6 inch. Just for looks and I think they look good. Still automatic trans.
a lot of aftermarket shifters come with the...Reverse lights switch and neutral safety switch...built in.
