Rear Brake lines
Discussion in 'Technical' started by alaskamaverick, Aug 29, 2014.
  1. alaskamaverick
    alaskamaverick Member
    Spokane, WA
    I've been working on replacing brake hoses/lines. following the brake line to the rear brakes, it comes to a brass "T" fitting which is some how installed on the axle housing. found hose leaking from that "T" however the hose is not threaded into the brass "T" fitting. I need to remove/replace the brass "T" fitting from the axle housing, how does one do that?
    It is a 8.8 rear axle out of a 74 Maverick
    Thanks alaskamaverick, living in Spokane!
  2. Mavman72
    You have to replace the rear line (Hose) the "T" is integral with it. There should be a vent nipple/hose for the rear axle attached to the "T" as well. It will unscrew from the axle tube and release the T fitting/brake hose from the axle...If its the cars original rear axle...Its' an 8 inch not 8.8.
  3. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    The "T" is made part of the hose, it is replace as a unit.
  4. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    Rock auto has them for less than $20.
  5. alaskamaverick
    Spokane, WA
    OK, outstanding it is threaded then. And Rock Auto has it, BENDIX Part # 77009 Rear; Center Intermediate. $20.79...ordered. thanks guys.
  6. 71gold
    the hole that mounts it to the axle housing isn't threaded...
  7. alaskamaverick
    Spokane, WA
    So how does one remove? does it pop out with leverage?
  8. Maverocket
    Northwest
    If you disconnect the vent hose you will se the integral nut. It screws into the axle housing.
  9. alaskamaverick
    Spokane, WA
    OK, I will take a look at it in the morning. Thank you
  10. alaskamaverick
    Spokane, WA
    Thanks for the help guys, I finally have operable brakes.
  11. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Since you are in Spokane, next time you need brake hose or tubing check out Inland Pacific Hose and Fittings, they can build them in house if they have the correct fittings.
  12. alaskamaverick
    Spokane, WA
    OMG, LMAO that would have been even greater news a week ago.
