rear brakes
Discussion in 'Technical' started by ChadS, Jan 8, 2006.
  1. ChadS
    ChadS MacGyver Smoker
    Indiana
    70 Maverick 5.0 EFI
    Just got done tearin apart the rear brakes on the maverick. What a mess!!!! Id assume these are the small brakes. is there a bigger set i can install without changing the back plate? I have to replace it all, so If I can get a better set up,,,, why not? I do have a 8.8 out of a ranger to install down the road,, but Im gonna run the stock rear end till it drops,,, Its in good shape, other than the brakes,, Im not going to abuse it too badly,,, I promise,, LOL!! So, what brakes will interchange to a better setup? My car is a 69.5. I think it is a 7.5 rear end. ChadS
  2. bmcdaniel
    Your 7.5" rear has 9" diameter brakes, 8" and 9" rears have 10" (usually) or 11" (occassionally) on some big cars and trucks. You're pretty much stuck with the small brakes with that rear.
  3. Acornridgeman
    Wisconsin
    Just throwing this out on the table - Is the Ford 7.5" in the early Maverick the same 7.5" found in the Bronco II and the small engine Ranger trucks? If it is, I bet the truck rear end would have a bigger rear brake than the cars did. :huh:
  4. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Another idea: what about the Granada 7.5? It would probably have larger brakes,too.
  5. stmanser
    Davenport, Iowa
    my stock 8" rear end with 4 lugs axles.. has a 9" x 2" drum..... and the 8" rearend that i have that has 5 lugs axles is a 10X2" drum
