Rear Disc Brakes
Discussion in 'Technical' started by x72COMETx, Nov 19, 2015.
  1. x72COMETx
    x72COMETx Member
    Vallejo CA
    I'm wanting to put disc brakes on the back of my car but need to know what all is needed to do this swap and what vehicle can i use parts off of,
    thank you,
  2. junrai
    junrai Member
    rancho cordova ca
    97 crown vic
  3. 71gold
    99-02 also
  4. x72COMETx
    x72COMETx Member
    Vallejo CA
    What all can i use
  5. 71gold
    backing plate...rotors...calipers...brackets...rubber hoses...pads and E-brake cable.
    Grand Marques also.
    3-4 of us get together and make a J/Y run and get a truck load...$45 a set.
    NCFatBoy, Crazy Larry and Static like this.
  6. Paul Masson
    1971 Grabber
    I used the 97-02 Crown vic brakes, but there is an interference between the lower caliper bolt and the leaf springs. I used a dummy bearing race and a spare housing to locate new holes in the backing plate, clocking the backing plate to allow the bolts to clear. I followed Frank's Tech Article for using Crown Vic cables inside Maverick conduits for the e-brake. I had a local cable/hydraulic hose company crimp-on new buttons on the ends of the cables.
    NCFatBoy, mojo and Krazy Comet like this.
  7. mojo
    I was just wondering Paul, do you know if others doing this conversion have to clock the plate to miss the spring?
    Great build you have going.
  8. 71gold
    I used the long shank caliper bolts. once broken loose they only unscrew 3-4 turns and the caliper can be removed. the bolt doesn't have to be removed.
    I clocked the Explorer brakes I had on it at one time.
  9. mojo
    Why u change the Explorer brakes to Crown Vic? Looks like all your bolt heads have no issue clearing the springs!
    Did u have to re-drill the backing plates -- can't tell from the pic's posted above?
  10. 71gold
    I figured out a way to hook up the E-brake.
    I clocked the Explorer mounting bracket so the bolt wouldn't hit. I had removed the backing plate and E-brake mec.
    this is a pic of the kit I put together.
    CA189HJN likes this.
  11. mojo
    What I'm getting from this, U cudn't figure out the E-brake on the Explorer, so, U went to the Crown Vic?
  12. x72COMETx
    x72COMETx Member
    Vallejo CA
    Is their a tech article on how these brakes go together on our cars or do i need to figure it out as i go
  13. mojo
  14. 71gold
    it wasn't I couldn't figure it out, it was I had cut the backing plate with the E-brake mec. off to make it a cleaner install. at that time it didn't have to work, just be purty...:slap:
  15. 71gold
    I thought at one time there was. we have done this to 5 Ga. mav/Comets so far. some of the Guys came over to my shop and we installed 2 sets in one day.
    I have a set of CV E-brake cables made up. we just swap the stock cables for them. then I make another set from them for the next swap...:thumbs2:
    injectedmav likes this.
