Rear Drum
Discussion in 'Technical' started by Dean Deeter, Sep 13, 2012.
  1. Dean Deeter
    Dean Deeter Member
    West Carrollton, Ohio
    1974 Comet GT and 1974 Maverick
    Has any one priced a rear drum lately for a 74 Maverick??? Over 100.00 at parts store. Think I will try to find one on here through sale section.
  2. Craig Selvey
    I see them on ebay all the time for cheap.
  3. 71gold
    that's why Terry I went with the Crown Vic. rear disc. brake swap...everything new for both sides...rotors, calipers and pads...$125...:yup:
  4. Dave B
    There are differences in the drums for some years of Mavericks, so just make sure you know what your getting. A 73 & earlier drum will not fit a 74 & up.
  5. Dean Deeter
    Dean Deeter Member
    Thanks that is what I heard!!
  6. Dean Deeter
    Dean Deeter Member
    What parts do I need??
  7. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    That sounds bogus to me. Years ago, I put some rear drums from a '75 Comet on my '73 Maverick, and ran them for years.
  8. Dave B
    If you read what I said, you'd realize you did the opposite. The axle stub size increased in 74, so an early drum (70-73) has a smaller hole, which will not fit over the larger axle 74 & up.
  9. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I just checked online, and O'Reilly sells them for $50ea.
    Same part number for 1973 and 1975. These are 10-inch drums.
  10. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    For the rear?
  11. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Yes. (and why do I have to type 10 or more characters to post a message?)
  12. Craig Selvey
    I think it is to prevent spam.
  13. Dean Deeter
    Dean Deeter Member
    Checking in Auto Krafters 70-73 drums are the same. 74-75 drums are ths same but different from 70-73. The 70-73 are 39.95 and the 74-75 are 119.95. At Oreillys the 74 drums for rear are apx. 100.00.
  14. Dave B
    74 & up drums seem to be hard to find, I get Street Rod guys calling me asking if I have any good used ones, since a lot of guys used 8" rears out of Mavericks in their rods.
  15. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I never knew that about Mavericks/Comets, but I just measured the hub diameter on a Granada rear-end that I have, and they measured 2-3/4", while my '73 Maverick hubs (stub?) measures 2-3/8". I guess I won't be using the Maverick brakes on that when I swap it in.
