rear end id
Discussion in 'Technical' started by 70maverick173, Jul 31, 2004.
  1. 70maverick173
    70maverick173 Member
    Carson, Iowa
    1970 1/2 Maverick
    I pulled these numbers off the tag on my rear end and i was wondering id anybody could make sense of them for me
    WDW-AA 5A"B or 8"
    2 79 8 530"B or 8"
    These are the only numbers on the tags. Any and all info would help thanks.
  2. PaulS
    2.79:1 ratio and 8" ring gear.
    The rest is date codes and I would have to look them up.
    PaulS
  3. 71gold
    good morning,
    is the " 1/2 maverick " you have your parts car?
    ...frank...
  4. 70maverick173
    Carson, Iowa
    1970 1/2 Maverick
    so i take it this is not a 9" rear end as I was told by the man i purchased it from.
  5. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    According to your tag, it is an 8 inch.
  6. scooper77515
    Where is that tag located? Is it a real "tag" or a stamped number on a flat spot?
  7. scooper77515
    Never mind, I found that tag.
    Next question...can anyone share a success story about converting a 2.79 8" to approximately 4.11 with some kind of locker? I need guidance in finding the right parts and instructions.
    Thanks in advance.
  8. 70maverick173
    Carson, Iowa
    1970 1/2 Maverick
    it was a real tag bolted to the rear on thge pumpkin.
  9. Grabber75
    Grabber75 Member
    Mount Vernon, Ohio
    1975 Maverick Grabber
    easiest way i know to tell an 8 inch from a 9 inch is the two bottom bolts on the pig, i.e. Carrier. an 8 inch you can use a ratchet and socket to take them off and on a 9 inch you have to use a wrench.
