rear end problems
Discussion in 'Technical' started by Zerpin, Jun 11, 2009.
  1. Zerpin
    Zerpin Member
    Richardson,tx 75081
    1976 Mercury Comet
    trying to pull the last cover off the rear end what is holding me up? the gears are moving when i try to pry it off?????
  2. bradleygt
    bradleygt Member
    grand rapids michigan
    1970 maverick
    did you pull out the axels:huh:
    brad:)
  3. Zerpin
    Zerpin Member
    Richardson,tx 75081
    1976 Mercury Comet
    what the heck??? i have to?
  4. Mavman72
    If you are pulling the chunk out of an 8" yup...
  5. Acornridgeman
    Wisconsin
    OK - I'm not following? What cover?
    8" has a removable carrier, no cover?
    :hmmm:
    If you are pulling the carrier out you need to pull out both axles - they are held in with 4 tee shaped bolts at the axle flange by the brakes.
  6. Zerpin
    Zerpin Member
    Richardson,tx 75081
    1976 Mercury Comet
    i got the tires off and the bolts out. the axles are stiff do i have to hammer them out or what?
  7. Zerpin
    Zerpin Member
    Richardson,tx 75081
    1976 Mercury Comet
    i had rear end problems if it is suppose to just slide out im in a world of hurt lol. idk how to repair the rear end once i get it out. my plan was to replace the seal and new fluid and hit the road. now its a project car got engine out. now i want to make the rear end right something is bent or broken. turns rough about a 1/4 then free turning the rest. like a warped rotor.
  8. Acornridgeman
    Wisconsin
    This is for 8" and 9" rears:
    Ok - to pull the axles - once you have the 4 bolts out that hold the brakes and axle onto the flange removed - put the brake drum back onto the wheel studs backwards and put on 2 or 3 of the lug nuts flat side towards backwards drum - put them on flush with the stud end not all the way tight - and use the drum as a slide hammer to pop the axle from the housing. You can now pull the complete third member (pumpkin).
    :thumbs2:
  9. Zerpin
    Zerpin Member
    Richardson,tx 75081
    1976 Mercury Comet
    ok ill try that thanks alot
  10. 71gold
    you only have to pull the axles out about 6-8", that should be enough to get the chunk out...:yup:
    note...there are...crush washers...around the bolts that are a witch to get off for the first time...
    ...Frank...:Handshake
  11. Zerpin
    Zerpin Member
    Richardson,tx 75081
    1976 Mercury Comet
    i have no clue what is wrong with the rear end it just made a weird noise going about 60 to 80 on the high way and has been leaking since i bought the car in 2007. i am in the process of an engine swap. so its not a rush to fix. should i take the parts i take out of the rear end to someone to get checked or should i get the right gears i want. any input will help. oh yeah and its a pain in the but to slide hammer the axles with the drum. i gave it a break i think i got like 1/2 inch on both sides hahaha
  12. 71gold
    have you pulled the driveshaft yet?
    if removed,was the tight spot there after you removed the driveshaft?
    ...:drive:...
  13. Zerpin
    Zerpin Member
    Richardson,tx 75081
    1976 Mercury Comet
    yes the tight spot is there when the drive shaft is off
  14. Zerpin
    Zerpin Member
    Richardson,tx 75081
    1976 Mercury Comet
    do you think its the bearings? it was leaking at the front of the rear at that seal.
  15. 71gold
    if you change the gear ratio you can have a new bearing kit installed at the same time...:yup:
    do you know what ratio you have now?
    ...:drive:...
