Rear end question
Discussion in 'General Maverick/Comet' started by NWMO_Maverick, Jun 2, 2018.
  1. NWMO_Maverick
    NWMO_Maverick Member
    Northwest MO
    1976 Maverick 302, C4
    Hey all,
    I assume this indicates an 8” Ford rear end with 3.00 gearing?
    I’ve dropped the drive shaft and removed the 10 nuts around the outside. Wanting to weld a nut on the bottom hole for future gear oil changes. I assume I need to remove the yolk before I can pull the front cover off?
    Do I have to worry about “adjustment”if the yolk has to come off? Pre-load?? Lash??
    I haven’t searched here yet, but wanted to post the other first.
    Thx
  2. 71gold
    the whole chunk comes out as a unit.
    it's awkward and heavy.
  3. 71gold
    if it is the first time it's been removed it will have the dreaded copper washers. they are a boy dog to get off...at least for me.
    Crazy Larry likes this.
  4. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    You need to pull the axles out too.
    That's not a "cover" on the front. It's the entire carrier with the gears and everything. No need to remove the yoke unless you are replacing the seal, bearings, etc.
  5. NWMO_Maverick
    Northwest MO
    Thanks guys, that makes sense. I will slide the axles out some, remove the small copper washers and get it out of there for a little clean-up and welding a nut to make future oil changes possible.
    Chris
  6. 71gold
    that's a lot of work just to put a drain plug in. what I do is install one if I ever have a reason to go into the rear end...axle change, bearings, gear change or add a track lock of some kind.
  7. 71gold
    and to remove the yoke you have to pull the chunk...:yup:
  8. NWMO_Maverick
    Northwest MO
    40+ years, likely never serviced, I’d rather have quick look and make it easier to service in the future.
    4 bolts on each end to slide the axles out 6” or so?
    Chris
  9. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    Yes, but you may want to pull the axles all the way out. The seals can tear from the weight of the axle resting on them.
    quickshift likes this.
  10. 71gold
    he"ll want to replace them anyway...:yup:
  11. NWMO_Maverick
    Northwest MO
    Hey all,
    Pulled axles and third member, no problems. I will work on it some this week and post what I end up doing.
    Chris
    Crazy Larry and 71gold like this.
  12. CaptainComet
    Nothing in the world like the smell of 40 year old gear oil. STINKY! You will never get the smell of that out of some things. If I ever load an old gear chunk into the trunk of a car, it goes inside a garbage bag, or two, to keep the smell contained.
    mojo likes this.
