rear end ratio
Discussion in 'General Maverick/Comet' started by Pete21136, Dec 14, 2024.
  1. Pete21136
    Pete21136 Member
    maryland
    1972 Comet
    Back in the day we were able to determine the rear end ratio by marking both the tire and the driveshaft and counting the number of revolutions of the driveshaft after one revolution of the tire. My question is. does this procedure work with an open type rear, or only with a locker or posi type rear?
  2. dyent
    dyent Member
    vancouver bc
    Should still work for open too........
    David
  3. Pete21136
    Pete21136 Member
    maryland
    1972 Comet
    I thought so too, but I had a guy tell me that it wouldn't work with an open rear. I'm pretty sure that back in the day we used to do this and most of us had open rears. Just wanted to make sure that my memory was correct. Thanks.
  4. Krazy Comet
    You have to turn both wheels for a accurate ratio check. If only one is turning the spider gears will affect reading.
    I'm yet to see any Mav/Comet factory gear other than 2.79(most) or 3.00(A/C) gears. Ratio code on door sticker.
    Ronald Hopkins and TeeEl like this.
  5. dyent
    dyent Member
    vancouver bc
    David
    TeeEl and Krazy Comet like this.
  6. TeeEl
    TeeEl Senior Member
    Colorado
    Good video, but Ford never made a 2.73 gear ratio for the 8-inch rear. It's most likely a 2.79...
    Krazy Comet likes this.
