Rear end swap is complete
Discussion in 'Technical' started by Will, Nov 1, 2005.
  1. Will
    Will I
    Waco
    74 2door - Small bumpers, 5.0 EFI, Tremec 3550, disc brake 8.8,MII front end, boosted
    Well, it took me a day to swap the rear end. But its finished, I pulled out the 8inch and in its place went an 8.8 with disc brakes. Boy it looks good under there. I've got to get my pictures developed and I'll post them up. The rear end is a little wider than the stock one but it works out since I'll be using a 17" Bullet wheel. I stuck them on afterwards and they have 255-60-17 on them and clear with plenty of room to spare I just need to get some with a shorter sidewall. So, guys dont get intimidated by it..... I'm only 20
    Pics are coming:bouncy::bouncy:
  2. 71gold
    and the 8.8 came from where???:huh: i will be looking for the pics....frank...:bouncy:
  3. waynes fords
    waynes fords Member
    fayetteville,Georgia
    1973 grabber,2004 ford dually,2000 gulfstream motorhome,2003 ford expedition,66 mustang gt
    probably an explorer
  4. Mavaholic
    Sounds great. Does the emergency brake hook up easily too?
  5. Will
    Will I
    Waco
    The rear end came out of a 90 Lincoln LSC, I havent hooked up the emergency brake yet but its going to be real simple
  6. bmcdaniel
    bmcdaniel Senile Member
    How wide is the 8.8 between wheel mounting surfaces?
  7. Mavaholic
    If its an explorer rear, its 59 3/8" mounting surface to mounting surface and 39 1/8" center to center on the perches.
  8. EFIMAV
    EFIMAV Member
    Davenport Iowa
    is the 90lsc or explorer a leaf spring rear? I thought both were coil spring?
  9. Mavaholic
    Explorers are leaf. Dont know about the LSC
  10. NICK DOMINICK
    Burke, Virginia
    I want to see the pics!!!!
  11. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Is it true that 8.8" rears have a different pinion offset?
    The swaps that I have heard of used two left (or was it right?) axle tubes and axles to mount properly in early Mustangs. Seems like the Mav would be same-same.
    Dave
  12. 71gold
    what he said :yup: ...frank...:bouncy:
  13. Mavaholic
    Dont know why that would be since the drive shaft comes down the center in both vehicles.
  14. mavman
    mavman Member
    Arkansas
    Actually the 8.8 does use a different offset than a 9" (and 8" as well). The 9" offset is .975" I believe. 8" is .875", IIRC. 8.8's are almost dead center, going from memory (too lazy to dig out my notes LOL).
    BTW, the 8.8 also uses less hypoid than the 8 & 9"..which means the pinion runs closer to the centerline of the ring gear, which means it has a little less frictional losses. One of the biggest reasons Ford used them over the 9" in later years before totally phasing out the tried & true 9".
    Personally, the work that it takes to install a 8.8 in a Mav/Comet could be used to install a 9", which is stronger and easier to deal with. But, that's just me. Save the 8.8 FOX body rears for guys (like me) that need the 8.8 as an upgrade to the lowly 7.5's.......and yes, the little 4 banger in mine will kill a 7.5 rear.
    check the site:
    http://www.stangnet.com/tech/lug.html
  15. Will
    Will I
    Waco
    Yes, from what mavman has said the 8.8 does have its advantages, both the 9" and 8.8 can both be built to handle the same amout of power. All in all it wasnt that much work to put it in. It only took me a day but could have been less if I wouldn't of had to do some running around.Also would have been quicker if I had an extra set of hands putting it in.
    The LSC rear end is not a leaf rear, the total cost of the swap was 15$...including the rear end.Which the 15$ was for the leaf spring perches.Yes thats right 15$. Patience is the key...lol. I traded a 1979 Capri for a 90 LSC that had a blown tranny. I pulled the motor, stuck it in the mav and the rear end.
    I'm trying to use up the rest of the pictures on the disposable right now. Pics are coming asap along with a write up.
