Rear end
Discussion in 'General Maverick/Comet' started by SamsDad, Mar 23, 2014.
  1. SamsDad
    SamsDad Member
    Little Rock, Ar
    1973 LDO turned Grabber Clone
    I'm sure this has been covered somewhere but I can't find it..........seeing as our car needs disc brakes added, a locker (was going to run mini spool but that's dangerouse ...and weak) there is surely an 8.8 already with disc brakes and a limited slip rear end in something that will fit in the Mav.
    Then all thats need is a gear ratio change, I have seen full rears for as little as $250 complete in salvage yards....what Ford has one that will fit the Mav?
    Gotta be one...surely:hmmm:
  2. Dave B
    No 8.8 is a direct fit.
  3. SamsDad
    SamsDad Member
    Little Rock, Ar
    Yes?
    Are you saying an 8.8 is a direct fit? if so which car is the best donor to grab one from?
  4. mercgt73
    mercgt73 Member
    Dave is saying that an 8.8 differential is not a direct fit, regardless of what it comes from.
    Do a search for 8.8 swap. It has been done, but it requires modification.
  5. Dave B
  6. SamsDad
    SamsDad Member
    Little Rock, Ar
    Oh
    OK I misunderstood, is there a rear end with disc and limited slip that is a direct fit or what rear is the easiest swap?:Handshake
  7. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    57 ford car has a 9 inch 1/2 wider
  8. SamsDad
    SamsDad Member
    Little Rock, Ar
    and it's a limited slip that only requires a ring and pinion change to lower the gears? the 1/2 inch is not even an issue, wonder if these can even be found still?
  9. silver70
    silver70 Eric
    Phoenix, AZ
    '70 Maverick
    Up until '67 Ford had the "Equa-lock" in its carriers. Later, the "Track-lock" came into the picture. The Track-lock is the better of the two, is easier to find parts for, and holds its capability better over time. So, if you find something pre-'67, just verify what's inside before you buy.
    Eric
  10. rthomas771
    Most 57-59 Ford rears I came across came with a 3.50:1 and were peg legged grey casting. How much lower do you want to go?
  11. mavgrab302
  12. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    65-66 Mustang is a whole lot easier to find look around on them the prices vary a great deal I've seen them go for 250.00 to 300.00
  13. SamsDad
    SamsDad Member
    Little Rock, Ar
    When I input my car into the fit match, it says: this part is "not compatible with your car"!
  14. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
    Sams, contact
    Leadmine Products and speak with Jeff -- His phone number is #417-733-1012
    Tell him Levi with the Maverick sent you -- He will take care of you.
    He can send you a 9" housing, axle tubes, and your choice of axle flanges along with T bolts for. He can even build it to your specs so everything you have is bolt on to the housing for around $400/or less.
    Also, his link to the website is blow in my signature.
  15. mercgt73
    mercgt73 Member
    Correct. Remember, if a Maverick came with a 9" rear disc brake option, you would not be hunting around for a non-Maverick rear end.
    Welcome to the world of modification.
