Rear frame rail repair
Discussion in 'Technical' started by cometguy, Nov 16, 2006.
  1. cometguy
    cometguy Member
    Schomberg, Ontario, Canada
    72 Comet GT 302/AOD, 1972 Mustang NHRA Stock Eliminator 351C
    I would like to get some opinions on the options for rear frame rail repair. Am I correct in the assumption that pre-fabricated sections are not available as they are for Mustangs? Has anyone used a Mustang section? The critical area includes the rear anchor point for the leaf spring.
  2. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    what happen to yours rust? wrecked?
  3. cometguy
    cometguy Member
    The evil rust worm:cry:
  4. eddie1975
    Martinsburg, WV
    sold
    you could prolly buy some square tubing and make your own, not sure about mustangs, i would say they are close but i have no idea
  5. Jean Doll
    Palmerton, PA
    You might get lucky and find a good doner car in the junkyard with a decent frame rail you can use. You would just need to find someone who will cut it out.
  6. mavman
    mavman Member
    Arkansas
    That's a common problem on these cars. Solution...Junkyard. That's about the only place you'll find them, unless you know someone who's backhalfed their Maverick or Comet. Then you could get the original frame rails for cheap. Mustang rails are shaped differently, IIRC.
  7. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    Did you read his profile on the left,he's in Canada,no mav's or Comets in the junk yards here,and if you are lucky enough to find one chances are it will be junk too.Thats why we come to the south and drag all your nice clean rust free cars up here lol.Hey Dave are you going to finally start fixin up the Comet? Hope so i really like that car.Derek.
  8. cometguy
    cometguy Member
    Derek, the frame repair is in the racecar; no work being done on the Comet yet.
    BTW, did you notice Joe DaSilva's supercharged Comet in the Auto Trader? He's asking a tidy sum for it at @ 23K!!
    Also on the race car subject, I won a nice voucher from Strange Eng at the CanAm series banquet - disc brakes in the new year:yup:
  9. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Probably be just as easy to go ahead and back half it. Get a set of the preformed frame rails from Jeg's or Summit and go with a ladder bar or four link with coilovers. Might cost a bit more, but then you'd have what you really want! :evilsmile
  10. cometguy
    cometguy Member
    Did you say "might cost a bit more"? I think you're trying to add a couple zeros to my $75 budget!! Not to mention the fact that I'd need to graduate from Stock to Super Stock - bye bye 200" motor.
    Come on folks, is there no one who's tried a set of the Mustang rails? I think I'll get a set anyway; they're inexpensive and I will be using non-stock spring bushings anyway.:rolleyes:
  11. bmcdaniel
    You could always buy some sheet metal, make some cardboard templates of the rail's shape, and weld together your own box frame.
  12. Derek 5oComet
    Congats i heard you did good in the points this year:bananaman I just looked at Joe's Comet,man thats a nice car,kind of looks like yours.Me amd a few of the local boys are going to the track tomorrow,wish i could run the comet but have a vibration issue i'm still trying to figure out.Good luck with the frame rails.Derek.
  13. Dave B
    I have some 69 Mustang replacement frame sections that came with a Comet I bought a few years ago, there not even close to the Maverick/Comet style. The guy bought them to fix his Comet, when he found out they wouldn't work, he sold the car for parts.
  14. cometguy
    cometguy Member
    Maybe there's a difference between one Mustang version and another. I spoke with a fellow who's working on a '70 Maverick and he told me that he adapted a pair of rails intended to fit a '67 Mustang. I think this must be a more economical way of doing the repair, especially considering the fact that I'm not doing the work myself. I can deal with the powertrain stuff but I'm not a welder.
