Rear leaf spring questions...
Discussion in 'Technical' started by Farmall, Jul 12, 2009.
  1. Farmall
    Farmall Member
    New Mexico
    1972 Grabber & two 69.5 Mavericks
    Hello all,
    I have searched the archives and read lots of information, but still looking for some reference to the Ford part numbers on the bottem of the spring just behind the u-bolts and plate. Does anyone a have a cross to these part numbers and the actual spring rate? Of just basic info on which Mavericks had the heavyest springs, I would assume a late car (because they got heavier), 4-door (also weight) and maybe Air Con. would get higher spring rate springs.
    I sort of doubt this information (part number cross) is available, but thought I would give it a try. There is some amazing information that comes through this forum so maybe I will get lucky.
    Has anyone added a leaf from another set of used original springs and made it work OK? A couple of my cars have saggy rear springs and just trying to find something that might work untill I can get new springs.
    Thanks again, Farmall
  2. maverick75
    Iook in the tech articles,theres an econoline spring swap write up.
  3. Farmall
    Farmall Member
    New Mexico
    Thanks Maverick75,
    I'll take another look at that.
    I appreciate it!
    Farmall
