Rear lower corners
Discussion in 'Cosmetic' started by blugene, Nov 25, 2009.
  1. blugene
    I gave Maverick Man a suggestion about making them. The studs on mine broke off as I was removing them. I got lucky on this
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=290371643320&ssPageName=STRK:MEWNX:IT
    Seems like either studs or nuts could be used. Weld whichever on a plate that has the hole pattern and set it in the mold. If the plate is thick enough it can be tapped. Provide the matching bolts or nuts and box it all up. Small managable part that some of us need. A break from the big hoods that some of you want lol. No reply yet so maybe he's working on more spoiler sets that WE want. :cool:
  2. Dave B
    Those are 73 only, not really popular..I have 3 sets I'll never use.
  3. Joe Dirt
    ive got a set also ill never use lol ;)
  4. blugene
    So what's back there then? I've never actualy studied this area.
  5. Dave B
    On 70-72's there's a little filler thingy. Since the bumpers fit tighter than they do on 73's.
  6. blugene
    So does that mean that the 73 has a different bumper? Now i'm confused.
  7. Jamie Miles
    Three more sets here I'll never use. :rolleyes:
    Gene, do you need 7 sets so you can have 6 sets you'll never use? :rofl2:
  8. blugene
    Ay, they will be worth something as they begin to loose their studs. ... That's if the ones you guys have still have the studs. So yea, send all of the ones with good studs to me :dancing:
  9. rthomas771
    Same bumper size...different mounts
  10. rthomas771
    Glue in another stud.
  11. Joe Dirt
    that extension sure looks familier :tiphat:
  12. blugene
    That makes sense now, thanks.
    I didn't think of that. My luck my glue probobly wouldn't work tho.
  13. Dave B
    Man, this has been discussed at least 3 time in the last few months, about the difference between 73 back bumpers, and 70-72's. Gene, you need to spend more time online. :D
  14. rthomas771
    You gotta glue a nut inside it so it will stick...use epoxy glue.
  15. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Now Gene got some stud work to do !!!! hee hee
