rear main seal recommendations??
Discussion in 'General Maverick/Comet' started by noodledood2, Jan 9, 2015.
  1. noodledood2
    noodledood2 Member
    Turlock, CA
    1971 maverick 302
    I replaced the rear main seal once but it seems to still be leaking. What brands do you use? Of course I installed with some good Ole rtv. I also am going to be replacing the rear pump seal. Anything I should know? I'm getting oil and trani fluid leaking from the bellhousing (the front in between motor/transmission).
  2. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Is this a 1 piece or 2 piece seal? Felpro brand seals have always been good to me.
  3. 71gold
    do you have the correct flexplate?
  4. rthomas771
    Did you put thread sealer on the flexplate bolts at the crankshaft?
  5. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    FELPRO 2921 is the recommended choice for the rear main .
    Cometized
    (Chip)
  6. noodledood2
    noodledood2 Member
    Turlock, CA
    1971 maverick 302
    It is a one piece seal.
    Yes I did use thread sealer on the bolts.
    And I do believe it is the correct flexplate.
  7. Bryant
    fel pro has a ptfe rubber seal. part #BS40644
    its better than the standard rubber ones.
    make sure your crank seal surface has no groves or knicks on it.
    is the rear main cap sealed to the block?
  8. bmcdaniel
    And put a film of grease between the seal and the crank to avoid a dry start.
  9. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    The FelPro 2921 Seal is a "Performance" Seal .. the BS 40644 is for a "Stock" Rebuilders Replacement Seal ..
    I think there is a difference of $ 6.00 more for the Good One .. I STILL recommend the FelPro 2921 for the
    engine . Hope this helps .
    Cometized
    (Chip)
  10. Bryant
    ah ok. good to know.
