rear seat delete weight
Discussion in 'General Maverick/Comet' started by HOMERMAV, Jan 27, 2010.
  1. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    i got to weigh the seats out of my maverick and together they are 35 pounds. then i weighed the delete and it weighs 18 pounds a reduction of 17 pounds.not a whole lot but every little bit helps.
    john
  2. comrick317
    comrick317 Banned
    Mississauga, Ontario
    1976 Mercury Comet
    Good to know, thanks for the info.
  3. blugene
    So I can skip the diet :biglaugh:
  4. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    you bet gene you can eat all the pie you want
  5. don graham
    Pies waiting Gene...Get back down here.:)
  6. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    what material did you use? it would make a difference in the weight
  7. rthomas771
    Speaking of weight. I found this interesting. Check out how the weight of removing an A/C will affect the weight of the front and rear axle. Also notice how removing a 8 lbs Stereo will cut 6 lbs from the front axle and 2 lbs from the rear but cutting the weight of removing outside mirrors only affects the front axle weight.
    (Click pic 3 times)
