Rear seat side panels
Discussion in 'Technical' started by rickm, Mar 27, 2011.
  1. rickm
    rickm Member
    Owosso Mi
    What is the trick to removing these ? I have removed alll the screws and I don't want to just start jerking on them. I'm doing speakers and there is no way I can get in the trunk, bad knees and hips. I also would like to put some sound deadner behind them. Thanks Rick
  2. Joe Dirt
    did you remove the screws behind the seat?
  3. rickm
    rickm Member
    Owosso Mi
    I removed the seat and then took out the 2 screws that held the seat back and lifted it up and removed it. I removed the 2 screws that held the package tray.
  4. rickm
    rickm Member
    Owosso Mi
    This is where I'm at now ?
  5. Joe Dirt
    assuming the srew at the top of the package tray is out (cant see in pic)
    and the the sill plate is out and the screw in the door jamb it should come up and forward
  6. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    You probably missed the door jamb screw if I had to guess. They just pop right out like Joe Dirt said.
  7. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Just be careful with the top back edge! It will punch a hole in the headliner, especially if it is old and brittle! Watch it closely when you come up with the rear portion!
  8. mojo
    It seems to me u already have enough off to get to rear spk's, except for removing the gray covering to gain access to trunk area. The only reason I see to remove the 1/4 panel covers is to put in soundeadner and/or wires. I removed my panels to put in soundeadner - while they were off I paint the entire area.
    Im getting ready to change out my rear spk's while I have the rear seat out for re-upholstery.
    These shot are a year old and the sub is no longer there.
