Rear shackel
Discussion in 'Drag Racing' started by murphy88, Apr 4, 2014.
  1. murphy88
    murphy88 Member
    waterloo on
    73 maverick 76comet
    I want to put a offset shackel kit in the rear of my 73...i took of the 2 nuts off the inside... I beat the spring with a sledge...how does it come off being seized so bad?? I don't want to use a torch
  2. 71gold
    put the nuts on about half way...then tap them with a hammer...:yup:
  3. Boss302maverick
    Boss302maverick Member
    New Jersey
    1971 maverick grabber
    spray the bolts that go into the bushings with penetrating oil also.
  4. murphy88
    murphy88 Member
    waterloo on
    73 maverick 76comet
    Thanks..i got them out...what do guys use for bushing ???
  5. olerodder
    olerodder Member
    NorCal
    I used polly on mine, but if you are going to drive it on the street also I'd stick with rubber. Mine had the stock rubber and I assume they were in there since new, and car has seen hundreds of 10sec passes. I just wanted to stiffen things up a little.............IMHO
  6. murphy88
    murphy88 Member
    waterloo on
    73 maverick 76comet
    rubbers
    picked up all new rubbers at KW springs in kitchener ..they pressed in the new front ones tooo.. $ 62 bucs good deal
