Rear Shocks
Discussion in 'Technical' started by gdemopesq, Nov 12, 2007.
  1. gdemopesq
    gdemopesq MOTOR CITY MAV
    Michigan
    72 Maverick 302
    Thanks for the advice yesterday. The trick of jacking up the front arm allowed me to easily install the front shocks.
    I worked on the rear. Ordered Monroe air shocks specific for the 72 Mav. The top of it has two holes to mount like in the front. Except the rear shocks have an axle for the top mount. Anyway I am returning them tomorrow. Has anyone got a good pair of rear air shocks. Where did you get them? What brand?
  2. 71gold
    ...first...the general rule here is...no air shocks...more than a few have torn the upper shock mount loose with them.
    ...second...why do you think you need...air shocks...?
    if you are trying to lift a sagging rear...you need new...leaf springs...:yup:
    ...:outtahere:
  3. Rocco
    Rocco Member
    Chicago, IL
    1977 Maverick
    Do you have a picture of the problem? The rear shocks don't mount anything like the front.
  4. newtoford
    newtoford Member
    New Castle Delaware
    it sounds like your trying to put a set of front shocks on the rear?
  5. RobertBailey
    RobertBailey MCCI & MCG Member
    Lenoir City, Tennessee
    1972 Grabber Clone,1970 Maverick, 1973 Grabber, 1973 2dr, 1973 Maverick(Parts Car) 2000 Ford SD Truck PowerStroke
    I learned my lesson back in 1980 with my first maverick.....didnt take long before it ripped the right side off the car.
    Robert
  6. gdemopesq
    Michigan
    72 Maverick 302
    wrong shock
    The box label was correct, monroe put the wrong part in it. The rear has a stud on top, what they sent me was like the front shock. They are getting me the correct one.
  7. newtoford
    newtoford Member
    New Castle Delaware
    hopefully a non-air shock right?
  8. Jamie Miles
    I strongly suggest that you do not use air shocks. That area was not designed to support the weight of the car, and that is exactly what air shocks force it to do. They will punch right through the floor the trunk.
