rear shocks
Discussion in 'Technical' started by EFIMAV, Sep 19, 2009.
  1. EFIMAV
    EFIMAV Member
    Davenport Iowa
    Ok, need rear shocks! I purchased a set of KYB 343136 from the local store and they don't exactly fit. The bolt that goes through the eye on the top doesn't fit between the bracket and the trunk/floor pan on the passenger side. I guess I could cut the bolt down but I really shouldn't have to do this. The only way I see to install it would be to install the shock on the bolt and then install it in the bracket (not sure this will clear either). These are not designed like the original shocks with a stud on one side for the bracket and a bolt "attached" to the shock eyelet. The bolt is threaded on both sides with one going through the bracket and the other through the shock eyelet with a washer and nut on that side as well(this doesn't clear the floor/trunk pan). Any ideas?
  2. Bryant
    can you put the shock on the orignal bolt?
