How do you remove these windows ? are there screws under the weather seal ? Also I know its been talked about but cant find the info on replacing the seals using another cars seals (honda I think)
unscrew the latch mechanism, open the windows a little more. you will then see the screws from the inside, under the chrome trim. you can get them out without removing the weather seal.
Thanks, I knew I saw it somewhere... Will any year will work ? Mine are dry rotted but did come out in one peice....
