Rear Sump Oil Pan
Discussion in 'General Maverick/Comet' started by BigDog41364, Apr 30, 2015.
  1. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    I,m having an issue trying to find a rear sump oil pan for a "77" 302 block. all the ones i have found are for "83" and later. Will the newer pans fit in an older block?
  2. rthomas771
  3. Krazy Comet
    Problem is the dip stick tube is in block for rear sump applications and I doubt there will be a hole in a '77 block... Need a pan with dip tube in it...
  4. Mavman72
    Rear sump pan will not clear the steering components on a stock mav frt suspension...
  5. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    I,m installing a MII and rack and pinion steering. That's why i need the rear sump pan :)
  6. Mavman72
    You should be golden then...:thumbs2:
