What kind of sealant do you guys use on your rear windshield and how do you seal it on the bottom where it meets with the trunk? Prior to removing my vinyl top I had water leaking in from the bottom corners. I just finished welding all the holes so there shouldn't be any more water leaking trough. I just want to make sure I seal it right cause everything in my trunk gets wet.
Ok and just apply it on the bottom of the windshield? Is there any other type of sealants that I want to use once the window is installed? Do I repeat the process with the front windshield as well?
