Rebuild vs. buying new transmission
Discussion in 'General Maverick/Comet' started by rag9836, Sep 23, 2019.
  1. rag9836
    rag9836 1972 Comet, 67K
    Riverside, CA
    Comet
    Have the original C4 transmission in the car. Pulling it this weekend.
    Local shop with a good reputation wants $600 for a rebuild, a new Hugh's performance trans is $1,200.
    I am no expert by any means, learning as I go. Don't want to go cheap and then have to pull it again due to something else...but if it's all the same, I'll save $600.
    Opinions?
  2. William623
    William623 Member
    Orlando
    1973 ford maverick grabber
    It all depends on what you are trying to do. If you are doing a stock/mild 302 then a rebuild is fine. If you are going crazy HP then you are going to need a performance transmission. As long as they know what they are doing the rebuild should be fine.
    BBMS18 likes this.
  3. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    Ask each place for a detailed list of what they’re doing to the transmission for that price.
  4. ike72com
    ike72com Member
    Charleston SC
    Not sure of your abilities.. but if you can drop a trans and install it. I'll bet money your can rebuild it.
    Hardest part is installing in my opinion.
  5. 71gold
    you will also need a new converter. around here that's the only way my Guy will stand behind his rebuild.
    $600 is the price around here also...converter extra.
    Earl Branham and Rasit like this.
  6. rag9836
    Riverside, CA
    Comet
    Thanks guys. We'll see how it goes this weekend!
