Rebuilding a C4?
Discussion in 'Transmissions' started by simple man, Feb 27, 2010.
  1. simple man
    simple man Member
    Bunnell,Florida
    When you get a C4 rebuilt,do you still have to use type F fluid? It is becoming really hard to find. :hmmm:
  2. don graham
    Always use type F. I get mine at Autozone.:)
  3. justin has a 74
    kentucky
    walmart has rows of it
  4. PaulS
    Unless you switch to racing type frictions (which do not work well on the street) you should run type "F" in all C4s. Other fluids lubricate too much and allow the friction material to slip. That generates heat and the heat destroys the C4 FAST!
  5. simple man
    simple man Member
    Bunnell,Florida
    Thanks to all! I found I can get it through NAPA auto parts,and pretty reasonably. I use it in my maverick but I wasn`t for sure. The Fairlane also uses it too.
