reclining bucket seat repair
Discussion in 'Technical' started by Yellow72Mavrick, May 18, 2006.
  1. Yellow72Mavrick
    Yellow72Mavrick Banned
    Memphis, Tenn.
    1977 maverick 2 door ( my sons) 250 c4
    Has anyone repaired their reclining bucket seat? My son's passenger seat now reclines all the time after he heard a pop inside the seat. Is there a cable or some type of lock that may have broken? He has not looked inside yet. These are the stock 77 bucket seats for his maverick...Jim:huh:
  2. ME262_1970Maver
    ME262_1970Maver Heavy Metal Maverick
    Red Hook New York
    1970 Grabber 1994 Mazda 626 DX 191K
    Jim,
    I think the spring inside may have snapped, I had that happen to me in 1974 Dodge Dart Swinger 4DR. Not, the same car by any means, but should be similiar fix, the sping was attached to cable, that held it locked, until you push the release lever at the base of the seat. This is just my guess.
    Good luck! (y)
    Erik
  3. Masta T
    Masta T 1337 |\/|4\/3R1(K
    Florida
    1973 Maverick 302
    Yea, my seat was like that for a while, and i used a wood board to prop it up lol.
    i pulled the seat apart and i saw in the hinge that metal pin on both sides of the seat had been broken.
    to fix. i sawed off the pins. then i drilled out the holes.
    I took a bolt, with a rounded flathead tip, and ground it down some. so that it could move inside the hinge. and i just put it in the same spot as the old broken pin.
    and so now the seat works fine.
