...recoil...
Discussion in 'Technical' started by 71gold, Apr 27, 2008.
  1. 71gold
    need suggestions for a new coil to run with my MSD Dist. :Handshake
    ...Frank...
  2. mean_maverick
    why not a blaster 2? :huh: ive heard good things from them...
  3. svthauln
    svthauln Member
    Mounds,Ok
    1972 maverick
    If you have a 6A box as well you better use a blaster 3.I had a problem with the blaster 2 arcing from the coil tower to the positive post.MSD said to use the blaster 3 with the taller tower and that would not happen.Worked great for many miles/years.
  4. mean_maverick
    as of right now, im running the Super Stock Accel coil (i had it laying around) and a 6AL box and so far so good, but ive only put about 8 miles on them so far
  5. tim keck
    sharps chapel,Tn
    I actually got away with a new,stock coil from Advance after we accidentally cracked the top of the Blaster 2.It(the stocker) worked fine,even on the bottle.
  6. Dave B
    I have a brand spanking new Blaster coil still in the package, and it says "Frank" on it!!
  7. don graham
    I'm running the Blaster SS coil. Got a different look to it. summit has it. Part# msd-8207---$43.10.:)
  8. 71gold
    Hey Buddy,
    what would it cost to get my address put under that name :huh:
    ...DFF...
  9. 71gold
    i'm thinking about a...6A box...also. :yup:
    thanks for the tip...:Handshake
  10. mean_maverick
    or go 6AL and get the limiter just in case u decide to take a nap while behind the wheel :biglaugh: (y)
    ...FFD...
  11. Dave B
    Will this work??
  12. 71gold
    ...works for me...:thumbs2:
    ...DFF...
  13. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    Frank....I highly recommend getting a 6AL box, but if you want a 6A, I have a spare setting here....I'll even put a warrantee on it....just send me some $$$.
  14. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Going with the blaster coil and the 6AL is the way to go.
    Dan
  15. Dave B
    Except the coil I have doesn't work with the 6AL :( (Frank already knows)
