Recommended 302 28oz Harmonic Balancer?
Discussion in 'Technical' started by Jory, Jun 10, 2013.
  1. Jory
    Jory Member
    Greenville, Texas
    1971 Ford Maverick 4-door
  2. lm14
    lm14 Member
    Iowa
  3. Jory
    Jory Member
    Greenville, Texas
    Thanks Im14. My only problem with that one is that I have to buy the spacers separately, where a few of the others include them (if needed). Still a good option though, especially if I don't need a spacer anyway...anyone know for sure?
    Any other recommendations?
  4. groberts101
    groberts101 Member
    Minneapolis, MN
    IIRC.. most won't require using spacers unless you run later blocks with newer serpentine belt setups. I've never had to run them on early blocks and my Fluidamper doesn't require one on my 73 block running v-belts.
    you may want to call the mfgrs directly to get proper advice on spacer requirements for your particular setup. Plus.. it'll be much faster than playing the chat game around here for 2 days just to figure it out.
  5. lm14
    lm14 Member
    Iowa
    Go to the Speedway link and check "notes" to the right of the picture. It tells you exactly what spacers are needed when.
    SPark
