red or yellow top Optima battery...
Discussion in 'Maverick/Comet Projects' started by 71gold, Oct 11, 2016.
  1. 71gold
    I have a red top, it's been in the car for about 6-7 years. it's down to 11.3 volts so I'm thinking I may need a new battery soon.
    is one better than the other for a car?
    :drive:...:chirp:...:bouncy:
  2. 71gold
    I found the purchase date...6/07...older than I though...:thumbs2:
    mavgrab302 likes this.
  3. Krazy Comet
    Well I take it yours is still starting so it's probably OK, but here is a video on how to recharge a dead one that won't recharge...
    I've never owned a AGM battery, one in my Comet came from Sam's Club in '05, still cranks fine... Last time I checked still had 12.6v at rest...
  4. 71gold
    thanks for the vid. I recharged it the other day and yesterday it was down again. I have a disconnect on my system so I'm thinking it's not a drain. it clicked several times before engaging and then started. after the recharge the other day it would fire right up.
    on the way to Summit this morning for a new one.
    Red, Yellow or Blue top?
  5. Krazy Comet
  6. 71gold
  7. 71gold
    a friend and I went to Summit today and I bought another red top with top/side posts...:thumbs2:
  8. captainmack
    captainmack Quad Door
    good choice, redare for starting, blue are for deep disharge / deep cycle as in a house battery in a trailer or a boat, and yellow are in between, being a starting baattery and a deep cycle, like you sit and listen to the radio in your car and also want to start.. I ran a yellow a left over from a job it was fine. Any of them will easily start a car, but the red will do it better / more years.
    Next time (8 years or so ,lol) buy a Odyssey battery they are superior.
  9. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Iv had a red in mone for almost 10 years to. It makes me nervous.
  10. werner
    werner Member
    pa usa
    71 GT mercury comet
    I have a yellow one. The yellow optima battery is a deep cycle battery and you let drain and recharge many times. The one if you don't drive the car all the time
  11. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Neither. Odyssey batteries are better.
  12. werner
    werner Member
    pa usa
    71 GT mercury comet
    Never had a problem with it. Yellow is the best for rechargeable. Red is just for daily use. All preference. But I like them. I did researched before I but the yellow one. I wanted a deep cycle battery and never let me down.
  13. Static
    Static Member
    Apache Junction AZ
    1975 Maverick 2 Door
    I haven't had very good luck with yellow tops. The first one I had was good for 5 years. The last few I had have managed maybe 2 years. Not made like they used to be.
  14. Krazy Comet
    Never owned one, my Comet has a Walmart battery I bought in Sept '05 for my Cobra Jet... Now 11+ years it still spins over just fine(no doubt on borrowed time, probably repl next spring)... At 8 years and 5 months the Advance battery just died in my old F-150, bought the wife a new Walmart battery for her Grand Marquis and swapped her 6+ year old Walmart batt into the truck... The Advance battery and battery from wife's grand Marquis were both mfg'd by Johnson Controls, generally good products... I believe one in Comet was mfgr'd by Exide
  15. Krazy Comet
    Well I need a new battery... No not for the Walmart Stupid Crank that was 11 years old in Sept, the eight year old Motorcrap in my Cobra has done just that, crapped... Since it's so nice(and stuff is sweating inside the garage), decided to start them both... Comet had no issues, battery in Cobra Jet barely burns the dome light(no I didn't bother checking voltage, no doubt less than 3-4)... After the Comet got it run, I swapped batteries, old Cobra Jet fired right up...
