Remote oil filter
Discussion in 'Technical' started by fastback86, Jan 1, 2013.
  1. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    Does anyone who runs a remote engine oil filter have any photos of theirs installed? I'm trying to decide the best place to mount it and looking for examples.
  2. rthomas771
    Don't have one but where ever you mount it be sure not to use 90* fittings...it will cut down on your oil pressure when the oil dead heads into the fitting. use 2 45's or a long sweep 90.
  3. igoback70
    igoback70 Member
    IN
    70 Maverick
    What motor are you running that requires filter relocation ?
  4. Streamliner
    Streamliner Member
  5. fastback86
    FL
    A small block, but the headers require the oil filter to be moved.
  6. 71gold
    mine was mounted in same location...:yup:
  7. fastback86
    FL
    How much of a mess does that make during an oil change?
  8. 71Mavrk
    71Mavrk Member
    Nevada
    Sorry to hijack the thread but...
    Streamlier, where did you get the shock tower braces. I'm looking to do an EFI setup and need to find some braces that will work. Your's look like they might.
  9. Streamliner
    Streamliner Member
    It's homemade...4 brackets welded to the shock towere, threaded aluminum tube and 2- 5'8"s heims
  10. RabidCustoms
    I had duals mounted in the same location,....as for mess, I would take a plastic bag and slip under the filters when removing them, never made much mess at all.
  11. igoback70
    igoback70 Member
    IN
    70 Maverick
    OK, gotta ask, what brand headers require you to relocate the filter in a small block Maverick ?
  12. igoback70
    igoback70 Member
    IN
    70 Maverick
    I have only had to relocate a filter once, i put a 5.0 in a 1983 Ford Ranger, the steering gear box was in the way so the filter needed to be relocated.
  13. fastback86
    FL
    Crites. #5 turns down right towards it.
  14. olerodder
    olerodder Member
    NorCal
    For what it's worth here are a few pictures of my remote.
    Sorry for the mess, but I'm redoing the wiring for the pre-oiler.
  15. igoback70
    igoback70 Member
    IN
    70 Maverick
    Gotcha ;) 1and3/4 primes, was just trying to figure out why the relocater was needed.
