Removing paint off chrome
Discussion in 'Technical' started by gdemopesq, Feb 9, 2008.
  1. gdemopesq
    gdemopesq MOTOR CITY MAV
    Michigan
    72 Maverick 302
    I am putting 68 Cougar tail lights on my Mav. Here is my problem, the grill cover for the tailights are black painted over chrome, only 20% of the chrome shows on these. I started removing the black paint with steel wool. There is beautiful chrome under there. Problem is I cant get the crannies and corners good with steel wool and it is taking forever. I used aircraft stripper. Doesnt help much.
    What would you do? I was thinking of a mild acid? Think it might eat up the chrome? I am on the verge of just painting it all black.
  2. Dave B
    Try oven cleaner, it might work.
  3. gunslinger68
    gunslinger68 Member
    Jackson, WI
    1970 Maverick-347,tr3550,9in,etc.etc.
    That stuff works very well on One Shot lettering enamel, may be the thing, or you could just throw them out in my garbage :D
  4. Craig Selvey
    I have always used aircraft stripper with great success. You just need to let it soak.
  5. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Acetone.
  6. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Brake fluid
  7. Jean Doll
    Palmerton, PA
    That's what we use too. The stripper needs to sit for about 10 minutes or longer in order for it to completely lift the paint from the chrome. After it has soaked for a while you can then use the steel wool or a stiff brush to get into all the little nooks and crannies. Sometimes I use laquer thinner on the steel wool to help get the left over paint and stripper off too. The thinner will help to melt the paint and it effectively ' kills ' the paint stripper. Just keep in mind that this prosess will not work on aluminum that has a black anodized finish.
  8. monster 302
    monster 302 Member
    Meridianville,Alabama
    1976 ford maverick
    i used googone and a heat gun came right off.
  9. baddad457
    X 2:thumbs2:
  10. baddad457
    I took the time to paint the 9" that I just swapped into the Comet and got brake fluid on it from bleeding the brakes. Paint came right off where the fluid landed.:slap:
  11. GrabA72Mav
    GrabA72Mav Living Our 2nd Childhood
    Eastern Iowa
    72 Maverick (Sold) 76 Aspen R/T Super Pack
    I used paint stripper & a old scotch brite w/ a tooth brush. Just takes time nothing good gets done fast! Good Luck!!!
  12. PaulS
    If you use a stainless steel scrubber pad gently it will remove the paint without marking the chrome up. Paint stripper works but be sure to rinse it off when you are done and oil the chrome. Chrome is real hard but it is porous and the chemicals will allow water to get in behind the chrome. If you rinse it with hot water, dry it and then oil it the oil will penetrate and it won't rust under the chrome.
